Drop spindle
28 opens
13 copies
1 comment
Keith Selbo
Keith Selbo
Spin your own yarn without spending a fortune on a spinning wheel.
Bamboo Plywood
Bamboo Plywood
Cut wheel halves
16 minutes
Cut out the wheel halves on the x-carve using the digital design file.
insert the balast
4 minutes
cut two 4.3 in. lengths of eighth inch dia. 50/50 solder and insert one each into the grooves in the wheel halves. Glue the halves together.
make the shaft
cut a ten inch length of quarter inch dowel. taper one end by spinning it against a sander. Screw a threaded hook into the other end. If you can’t find a tiny hook, you can make one by opening an eyelet with pliers.
Insert the shaft
Insert the shaft in the wheel leaving the hooked end protruding approximately two and a quarter inches from the wheel.
finishing
Rub with boiled linseed oil. Let dry over night.
Spin
220 minutes
Forever actually.
For spinning instructions follow this link:
https://www.youtube.com/watch?v=7R0Lb1qA7kE
Jenna Richards
Cool project, I'm going to make one and try it.
Jenna Richards
