DIY Scrap Wood Trivet
487 opens
182 copies
Johnny Brooke
Johnny Brooke
I built a set of simple scrap wood wooden trivets using two methods: first, using “traditional” woodworking tools like my router table, and then using my Inventables X-Carve.
Create Trivet Blank & Run Easel File On One Side
I ran the Easel file on one side first, then flipped the trivet over and rotated it 90 degrees.
Run Easel File On Second Side Then Run Outline Operation
Run the Easel file again on the second side, then run the outline file : http://easel.inventables.com/projects/npTPeENu895Gl2an-lL23g
Roundover Edges, Sand & Finish
After the X-Carve is done, all that’s left to do is finishing. I rounded over my edges, did some sanding, and applied a few coats of polyurethane.
