DIY Modern Curved Plywood Lounger Chair
861 opens
213 copies
7 comments
Woodbrew
Woodbrew
We decided to put our design and engineering skills to the test by building a wooden live hinge lounge chair. The chair is made from 3/4" plywood and has walnut end caps.
Modern Lounge Chair
This week, we decided to put our design and engineering skills to the test by building a wooden live hinge lounge chair. The chair is made from 3/4" plywood and has walnut end caps. We used a technique called live hinge, where you take out material in a uniform pattern, which allows the plywood to compress and then bend.
Check out our YouTube channel for more fun projects:) www.youtube.com/woodbrew
Check Out Our Instagram!
https://www.instagram.com/woodbrew_/
BUILD FILES
Check out the build files for this chair! Send us a link via Instagram DM to your modified version.
Check Out All The Tools We Use!———
• Saw Stop Table Saw: http://amzn.to/2zC32kU
• Jig Saw: http://amzn.to/2znKft0
• Sander: http://amzn.to/2yAPHLc
• X-Carve Machine: https://goo.gl/4cA9JS
Products Used———-
• Half a sheet of 3/4" Birch plywood
• (2) 1 × 6 × 24 Walnut
• Waterlox Finish: https://goo.gl/JE5VHB
Patreon Page THANKS!———
Help support the show and get extra content!
Thank you Shane VanBuskirk for supporting our channel:)
https://goo.gl/jwVVcQ
Ivan McFarlan
Nice design. Where are the files for the legs?
Ivan McFarlan
ethan schweizer
very cool. What bit is it that you used? 1/4" single upcut spiral
ethan schweizer
Bill Karmis
Are there files for the legs?
Bill Karmis
Nick Arnold
I have been a woodworker for many years but admittedly I have never cut a living hinge from plywood. Am I missing something here? There seems to be no symmetry whatsoever, other than the Y coordinate. Not all of the rectangles are the same size. The pattern just looks off.
Nick Arnold
Gurbey Demirturk
There are no files. Design is on Easel. It is on the right side of the picture.
Gurbey Demirturk
Gurbey Demirturk
The legs are also on the same Easel file. Look at the left bottom of the page.
Gurbey Demirturk
Owen Hughes
I too cannot find the files for the legs. Also can I have the build files too. I am not on Instagram, in fact I don't know what it is.
Owen Hughes
