Dewalt cable holder
Chris Myers
Chris Myers
This is designed to hold the cable coming off of the Dewalt 611 used on the X Carve. The cable is to thick to go in the roller chain, so it basically hangs off the back of the gantry.
Flat Washer
Flat Washer
$2.99
Hex Nuts
Hex Nuts
$3.99
$6.98
X Carve Dewalt Cable Holder.stl
Step 1
Replace the rear two 5mm x 20 socket cap bolts used to hold the Z axis motor in place with two 5mm x 25 socket cap bolts.
Step 2
Press cable holder over the two bolts and nuts, pushing firmly against the rear of the Z axis plate. Secure with 2 – 5mm nuts and washers.
Step 3
Route cable through slot in holder and secure with zip ties.
