After changing the bits under my new Dewalt 611 router I found the stock wrench very troublesome. So I made one out of 3/4" Oak.
3-18-19:Glad this is being used by others!
I use this thing all of the time and I am still on the original.
It has some dog chew marks, but still working :-)
Hi Bill, you forgot to share your project into Easel, nice idea by the way!
Antonio Santiago
Kind of new at sharing projects, but I thought you only had to hit the Open in Easel Button: http://easel.inventables.com/projects/EP1Qjmgl-wYfjfq_M6bDdw
Bill Lawrence
You got it now! I guess you have to publish and share it. Thank you for the project, keep up the good work!
Antonio Santiago
Thanks for sharing, I made one from your Easel file about two months ago and it is so much better than the stock wrench (its collecting dust somewhere).
Arthur Pollack
Jeff, can you share the pic. I might do just that also. Great idea.
Bill Lawrence
Irony, I opened in easel, didn't have any quality wood, used some .50 scrap MDF, worked perfect. Haven't touched the stock wrench since. You can see the dirt all over mine to prove use... Good share... THANKS.
Mike Anderson
Makes me wish I would have saved my oak board ;-)
Bill Lawrence
I also made one for I didn't like the movement of the spindle using the wrench. I added one feature to the already designed spindle cut out. I drilled 2 1/4" holes through the tool thickness and inserted 2 pin magnets as to prevent the tool from sliding off of the spindle while reposition my grip
Shannon Dolese
Gary, What dint fit? Too loose, too tight?
Bill Lawrence
Too tight....sanded it down and it fights snug. Dumb question am I supposed to leave it on?
Gary Florencio
This was not made to leave it on.
I wanted a smaller tool to tighten the bit in the router, rather than the wrench that comes with it.
Alternatively, check the diameter of your cutting bit, if it is a bit smaller than .125" then the hole that is cut will be smaller.
Bill Lawrence
I made mine from HDPE. Used a 1/16 round over bit to clean it up. Works great! I wasn't sure about leaving it on. It was a tight fit but I wonder if it'll degrade the router performance and router itself over time?? I'll probably just take it off and make the inside hole bigger...
Pete Donchenko
Hole's to small (TWSS) will have to remake but edit the center, still using 1/8" bit. Love the concept though!
Leonard Jackson Provencher
Hello, great idea as I have problems with my hands, does anyone know if this will work with a Makita router, not sure if they all have a generic collet
Dale Parsons
Works just great. Makes bit changing without losing center much easier
John Choate
Antonio Santiago
Bill Lawrence
Antonio Santiago
Ken
Arthur Pollack
Rolando Corral
Allen Kh
Z Cost
Jeff Richmond
Bill Lawrence
Mike Anderson
Bill Lawrence
Shannon Dolese
Bill Lawrence
Shannon Dolese
Gary Florencio
Bill Lawrence
Gary Florencio
Bill Lawrence
Gary Florencio
Pete Donchenko
Dale Parsons
John Choate
