Customizable Wedding Sign
3286 opens
1280 copies
10 comments
Sam Alaimo
Sam Alaimo
This design features an olive branch design which is a symbol of fertility and peace. The text can be easily changed to create a custom gift.
Baltic Birch Plywood
12" × 12" × 3/4" Baltic Birch Plywood
Customize the text
Open the project and click on the text to change it to whatever you would like.
You can use the align tools to make sure everything is centered.
Carve
Once your design is done, you can carve the project.
I used a v-bit to get all of the details and eliminate the need to use two bits.
The second workpiece includes a square if you would like to carve out the design from a larger sheet.
Sanding sealer
OPTIONAL: Stain the wood if you would like it to be a different color. The go one with the next steps.
I wanted to paint in the letters, so before I did that, I used a sanding sealer to prevent the paint from bleeding into the wood.
Brush the sealer on, and let it dry for an hour. Make sure you get sealer in all the engraved parts.
Paint and sand
Once the sealer is dry, use paint (I used craft acrylic paint), to fill in the letters. Because the sanding sealer puts a protective layer over the wood, you can paint sloppy and get paint on the surface of the sign.
Once the paint is dry, take a sander or sandpaper to the surface of the sign and remove any excess paint.
Now you can add a clasp or carve a hole in the back to hang it up!
Andy dubrawski
How do you avoid sanding off the stain when sanding off the excess paint
Andy dubrawski
Sam Alaimo
Hi, I found the best way is to use a few layers of stain and then also a few extra layers of the sealer. You will also need to lightly sand the paint off. If you do take some of the stain off, you can go back in and touch up the stain with a smaller brush and avoid the painted areas.
Sam Alaimo
Jodi Batchelor
Hi, so I have been using the sealer and have found that I'm getting a very gummy residue that sticks into the details. Its very hard to get out. Anybody else found this? Any recommendations? Thanks!
Jodi Batchelor
Jodi Batchelor
I have been applying the sealer to the whole board so maybe it's too much? I thought it would help get the stain consistent with the sanding.
Jodi Batchelor
jason herrman
I stain then apply a couple coats of shellac to the wood to prevent bleed over. I use acrylic paint and wipe with a wet paper towel to remove excess.
jason herrman
John W. Andrews
what unit do i need to do this type of engraving or carving?
John W. Andrews
Eric M. Kipp
How does the copyright attribution work?
Eric M. Kipp
TIMOTHY ROBERTS
Hi did you have to do several coats of paint to get it to cover?
TIMOTHY ROBERTS
David Nevins
Replying to to - Jodi Batchelor To keep your stain from looking blotchy before you stain the wood use a pre-stain wood conditioner and you’ll get much better results. Can be found in any hardware store. I use MinWax brand but any should work.
David Nevins
Mark Copeland
You can also use a masking material. Just stain your wood and then add the sheet of masking prior to carving, After the carving, you can spray with shellac and then paint after the shellac dries. Then remove masking after paint dries.
Mark Copeland
