Corian Vessels
Studio Murmur
Studio Murmur
Chicago
Corain vessels made with Carvey and thermoformed into three dimensional volumes.
White Corian®
White Corian®
Color: White, Cut Tolerance: +/- 1/2 in, Dimensions: 10 in × 12 in, Thickness: 1/4 in
Tray1.svg
Tray2.svg
Tray3.svg
Cut parts in (3) passes
180 minutes
-Set up with a 1/16" Solid Carbide Fish Tail bit.
-Insert and secure a 8″ × 12″x .25" sheet of Corian material.
-Cut (3) passes using the associated .svg files
First pass – outer pattern
Second pass – pattern through cuts (this will take a couple hours)
Final pass – cut outline to release the part
Sand the edges smooth. If you’ve added tabs, remove them completely. Corian is very easy to sand so go easy. We used an old sheet of 150 grit and were able to quickly smooth out the edges with a block.
Create a mold
We did a simple two part mold using clay and 3/4" plywood. This allowed us to easily clamp the parts rather than wrestling with a vacuum bag. The bag may be necessary if you want a more complex form.
Heat for 25 minutes in a 325 degree oven
Place the part on a cookie sheet (Use parchment paper to line the sheet. This will keep the nasty chemicals out of the chocoloate chip cookies and will generally impress your mom.)
Place into a preheated oven for 25 minutes at 325 degrees.
Clamp and cool
45 minutes
Place the part in your mold. Take care to mark and center the part in the mold. Use a few spring clamps for making easy adjustments. Allow to cool for 45 minutes or until its cool to the touch.
Finish
Release from the mold and sand any areas that need a final touch. Since our mold was open at the bottom, we sanded the bottom of the part flat using a sanding block to keep it from wobbling. Boom.
Made one? Log in to add yours
Frank Welte
Which milling bit do you recommend?
Frank Welte
Studio Murmur
We used a 1/16" fish tail bit. https://www.inventables.com/technologies/solid-carbide-upcut-fish-tail-spiral-bits
Studio Murmur
brian saban
Seems the inside pattern file is missing :(
brian saban
Studio Murmur
Brian, I just downloaded the .zip file and all (3) files were in there. Maybe try again.
Studio Murmur
Mark Shuck
Three files are there but #2 and #3 are the perimeter cut. The center pattern file is missing.
Mark Shuck
Scott Eaton
Are these double-sided jobs? Hard to tell if the piece is flipped on the CNC.
Scott Eaton
Scott Eaton
My first attempt cracked in the oven, but I'll keep trying. :D
Scott Eaton
Ruth Egnater
Would the cut form bend over a heat safe bowl if layer on top in oven? Anyone tried this?
Ruth Egnater
Martin
325 degree Farenheight or Celsius? Thanks!
Martin
Greg Ellenberg
I attempted to download today 6/5/2019 and received the following: This site can’t be reached The webpage at https://www.inventables.com/projects/corian-vessels.zip might be temporarily down or it may have moved permanently to a new web address. ERR_INVALID_RESPONSE
Greg Ellenberg
