Copy of Laptop Stand for x-carve
0 opens
0 copies
Dennis A McAlister
Dennis A McAlister
I redesigned the laptop stand with an additional swivel for easier use
$5.99
Add to Cart
$5.99
What I did
I used the original file and adjusted a few things then after I made it I realized that an additional swivel would make it better.
2- 5/16″ × 4 1/2" bolts
1- 5/16″ × 2 1/2" bolt
1- 5/16″ × 1 1/2" bolt
4- 5/16" nuts
12-5/16" washers
1 1/4" course thread screws
Gorilla Wood glue
I used 3/4" plywood and 3/4" MDF that I had in the shop. I put all the components on one sheet 24′ × 24′ × 3/4" plywood, the laptop shelve I used 3/4" MDF it measured 12″ × 20″ then added a 1 1/4’ X 20" as a stop. I put a 1" diameter hole 3/8" deep in the laptop shelf to cover the 5/16" bolt head and washer on the top swivel.
