Contrast House Model Kit
644 opens
165 copies
1120 downloads 4 comments
Michael Curry
Michael Curry
Kansas City, Missouri
The Contrast House is a flat cut model kit that can be made using with your X-Carve. There are 8 sheets of parts that need to be cut. The other seven sheets are available in the linked Projects.
Baltic Birch Plywood
Baltic Birch Plywood (×8)
12" × 24" × 1/8" Baltic Birch Plywood
Instructions
The Contrast House is an adaptation of the Berea Contrast House available for free from makeCNC.com. These files have been adapted and optimized for carving on the X-Carve.
This kit has been re-designed to be carve from 1/8th inch or 3mm material. It needs to be carved with a 1/8th inch or 3mm mill bit.
To get the assembly instructions, order for a free set of Berea Contrast House plans at MakeCNC
Plans and assembly instructions are delivered digitally after completing check out.
The other seven easel projects are available by following these links:
Exterior Walls B
Interior Walls A
Interior Walls B
Roof A
Roof B
Floor A
Floor B
Casey kookla
thank you for your time donating this project to everyone! i greatly appreciate it!!
Casey kookla
Casey kookla
can someone please check out these files and tell me if the cut depths are backwards? I tried this and it seems its cutting wrong. all I loaded file, deleted all but 1 part for a test, and it cut the outline only part way through, and the shallow detail parts cut out all the way through!
Casey kookla
bornt be;lly
period
bornt be;lly
bornt be;lly
5 stars ate!!
bornt be;lly
