Coffee Table
Jalal Arbid
Jalal Arbid
Dubai, UAE
I Designed this coffee table using Fusion 360,
the material used MDF 2 sheets 600×600×6mm for this project,
I am working now to do the final prototype using 12mm MDF thick
laminated by wood veneer
Material used for this project
Cut down the MDF sheet to 600×600×6 mm 2 piece, Or through local carpenter.
Preparing Material
Clamp the MDF sheet to X CARVE waste board
Open up Easel
Open up Easel and click import G-code / G-code Import and select (Autodesk Fusion), Now you can start carving
Assembling
1- Break the tabs
2- Send
3- Glue
4- Assemble
5- Sand and Paint
Joyie Joyie
Wow!! So cute and unique style of coffee table..I would love to have one.:)"
Joyie Joyie
Jalal Arbid
Thanks a lot
Jalal Arbid
