Chair Furniture
1666 opens
432 copies
11 comments
Andrew Petzold
Andrew Petzold
Open Desk Design
Andrew Petzold
Thanks for the Comment Carlos!!!!! 11/9/2018
Andrew Petzold
David Peterson
Will the chair work with .476 birch plywood?
David Peterson
Andrew Petzold
David, I would do a test cut with 2 pieces and see if the joint is tight. If not scale it up or down and try again. 4/25/19
Andrew Petzold
Claren Heaton
Question. you have a 30x30 peace of plywood but when you go to carving it goes up to 31.5. 1.5 inches off the piece.
Claren Heaton
Andrew Petzold
I have never actually made this project. If I was to make it I might scale it down a little or change how the pieces sit. 4/30/19
Andrew Petzold
Noah H
What a great design Andrew! I think that it's really cool making furniture with the cnc. I also love how you fit the pieces. One thing I would suggest is making it a bit bigger if you have enough wood for the job. Other than that it is, again, a great design!
Noah H
Cody schmidt
is it missing the front part of the chair ???
Cody schmidt
Cody schmidt
nvm found it thanks Im new
Cody schmidt
robert
great design works with .467 birch plywood unmodified if you run as designed leave 1/8th bit in the program but install 1/16th bit into router thanks for the design
robert
Andrew Smith Milan
was the design taken down?
Andrew Smith Milan
