Cellphone stand
86 opens
48 copies
2 comments
Douglas Briney
Douglas Briney
Cellphone stand, made as a gift for a coworker. My Coworker is a huge Minnesota Vikings Fan hence the Viking cut using Easel’s new V bit Carving feature. This is a simple design that works great and can be modified to an shape you desire.
Carbide V-Bits
Carbide V-Bits
$15.77
Hard Maple
Hard Maple
6" × 12" × 1/16" Hard Maple
$5.71
$6.49
$27.97
Randy Estes
Nice Douglas. Can you tell me how you painted the cut path without the paint bleeding across the edges? Do you use a thicker acrylic paint and sand after?
Randy Estes
Douglas Briney
Hi Randy. I put a couple coats of semigloss minwax spray polyurethane and let it dry to seal the edges, then I sprayed two coats of standard black spray paint and sanded. It worked great.
Douglas Briney
