CC Glue Caddy
17 opens
12 copies
Keith Rutherford
Keith Rutherford
El Paso, Texas
Do your glue bottles tip over? This project will organize your 2 oz. Starbond glue bottles, tips and accessories. This simple two stage carve is a useful addition to any shop.
$5.99
Carbide Tip V-Bit 90 Degree - 1/4 in Cutting x 1/8 in Shank
Cutting Diameter: 1/4 in, Tip Angle: 90 Degree, Shank diameter: 1/8 in
$21.40
Cherry Wood
Cherry Wood
6" × 12" × 3/4" Cherry Wood
$10.86
$38.25
Secure and carve workpiece
45 minutes
I used the glue and tape method to secure the work piece to the spoil board. This is a simple two bit carve and you can do the V-bit first or second, it really shouldn’t make any difference. Sand the finished carve and finish with your favorite clear finish. I use Polycrylic spray because that is what I had available. After two coats of clear, I used a paper towel to rub black acrylic paint in the lettering. Two more coats of clear after the black acrylic left a satiny clear and smooth finish.
