Candle Holder
213 opens
34 copies
590 downloads 0 comments
Beyond Design
Beyond Design
Chicago, Illinois
Designed to fit 2" diameter pillar candles, this stand uses MDF ribs to create a colorful wall structure. As the candle runs low the light flickering through will change. A runny candle will create a nice effect as it starts to fill in between the ribs.
Black Corian®
Black Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$76.54
Purple MDF Sheet
Purple MDF Sheet
Dimensions: 12 in × 12 in, Thickness: 3/8 in, Color: Purple, Type: MDF
$7.00
$83.54
Candle.svg
Cut Wall Sections
Cut a set of wall sections out of the MDF color of your choice. This is a good time to use double sided tape and avoid cutting all of those tabs.
Use this EASEL link
Cut Flip Mill Holes
Cut registration holes for flip milling the corian base. Make sure your piece is 6" tall and between 10" to 12" wide.
Use this EASEL link
Mill Top Features
For this cut use a square or fishtail 1/8" endmill.
Use this EASEL link
Flip and Mill Chamfer
Flip the part over, using the registration holes as guidance. Mill the Chamfer onto the base, which will also cut the parts profile.
Use this EASEL link
Fit and Finish
The wall sections may require light sanding for a proper fit. You want these to fit, but be tight enough to stay in place without glue.
