Carbide Tip Straight 2 Flute - 1/8 in Cutting x 1/8 in Shank |
Quantity: 1, Shank Diameter: 1/8 in, Cutting Diameter: 1/8 in |
$5.99 |
¼" Bit Set for V-Carving |
Carbide Tip V-Bit 90 Degree - 1/2 in Cutting x 1/4 in Shank - 30342-01, Carbide Tip V-Bit 60 Degree - 1/2 in Cutting x 1/4 in Shank - 30342-02 |
$5.99 |
Using 3/4″ × 5″ × 20″ material use the following:
Open Easel to the project & select your speed / material type
http://easel.inventables.com/projects/FnKq9LPlFz0HVlgwR_pqpQ
Birtch (40ipm)
Maple (30ipm)
If these options don’t work for you and your experience, please contact me for SVG files.
In a week this message will be down and I’ll have an SVG available.
Please contact me if you have any questions.
Make a 45 degree miter cut on the end for the grill, the thin end will shape to the grill on first few uses.
I used a 1/4" Forsner Bit for the strap hole, but you can use a regular bit or whatever works.
In order to get the scraper to your grill, turn on your BBQ at high tempurature until as hot as possible, then clean grill with it. The wood will give on the thin parts leaving a custom impression!
