Camper Wood Welcome Mat
31 opens
17 copies
Shalee Sykes
Shalee Sykes
Kennewick, Washington
Love Camping? Camper need some Pizazz? Got Dirty Feet? If you answered yes to any of these questions a sturdy, functional, piece of eye candy can be found in this project. A DIY, Customizable Wood Welcome Mat made with Campers, Trees, and Text (v-bit) all found in the Inventables Pro Design Library!
Hard Maple
Hard Maple (×30)
6" × 12" × 3/4" Hard Maple
$325.80
6" × 12" × 3/4" Walnut
$11.43
$337.23
Lay Out Pieces
The fun part! Lay the pieces out in the final pattern to get ready for feeding the rope, this will make it much easier to put together
Cut out 14 pieces of 1/8 in rope 6 in longer than the height of the map. This gives us room to tie a not in-between each tile as we string them on. Tie knots at the top and bottom to secure. Repeat 14 times!
Assembly
Set out to Welcome Everyone!!!
Gather Supplies
720 minutes
This project requires cutting out 24 Campers and 28 Tree designs (as well as 8 maple squares, 6 walnut WANDER tiles, and 2 walnut squares. Feel free to move the Easel file around to get the most cuts out of your piece of wood.
Add Pizazz
If you would like to make your design more personal feel free to add a v-bit engraves name to one of your campers,
Drill
Drill 1/4 inch holes, equal distance form the ends of the tile, through the sides.
Finishing
One all your piece are cut get onto sanding. I hope you like sanding, lol.
Spray each piece with a clear protective enamel gloss to protect it from feet and dirt. Let dry.
