Buck Hook
Samantha Alaimo
Samantha Alaimo
Chicago
Inspired by mounted antlers, The Buck Hook is heat bent acrylic to hold keys, jewelry, hats, and more..
Brown Acrylic Sheet
Brown Acrylic Sheet
$2.14
Hi-Lo Screw
Hi-Lo Screw
Thread Size: #4-24, Length: 0.25 in, Finish: Zinc Plated, Quantity: 10
$2.14
Laser cut the file
On a 40 watt laser cutter I used the settings 20 speed and 100 power. All the lines are vector cuts.
Heat bend the antlers
Place the acrylic piece over a strip heater and wait for the plastic to warm. When the plastic looks ready to bend (about 3 minutes) bend the antler to the desired angle. Wait until it cools.
Mount on the wall
Pick the appropriate screws for the application of your Buck Hook ( jewelry and small items might require regular screws while wall anchors will be better for heavier use).
Mount the hook in the desired spot. Enjoy!
