I used the fidget app to create a basic fidget then manually expanded on the design using the easy tools in Easel. Total time to create this design was about 10 minutes and it works pretty well and actually fits in the hand despite having so many bearings.
The author’s moral rights;
Jerry Berg
jimi257
