Baby Room Decoration
267 opens
90 copies
4 comments
Jeff Talbot
Jeff Talbot from Inventables
Chicago, IL
Personalized gift for my nephew, who has an elephant theme in his bedroom. Designed in Easel and cut on Shapeoko 2.
White Corian®
White Corian®
Color: White, Dimensions: 10 in × 12 in, Thickness: 1/2 in, Cut Tolerance: +/- 1/2 in
Royce Meredith
Hey Jeff, could you upload an svg for this cool project? Thanks
Royce Meredith
joshua blom
Do you recall what your milling speeds were and what cutout tool you were using?
joshua blom
Jeff Talbot
Royce, I believe I just used an image from a google image search for "Elephant"
Jeff Talbot
Jeff Talbot
Joshua, I can't remember exactly what I used, but in general you would probably want to be somewhere in the range of 1/16" depth per pass at 30" / minute feed rate. It will depend on what bit size you are using and what kind of spindle you have, so you may want to adjust this based on your setup.
Jeff Talbot
