Baby Crib
201 opens
68 copies
545 downloads 0 comments
Kenneth Connell
Kenneth Connell
Jefferson City, USA
this is a design by Inventables user @Malek of a baby crib, I have copied the design files from Fusion 360 and converted them into svg and imported them into Easel. I made this full size for our Grandchild but it can be scaled for a baby doll.
MDF Wood
MDF Wood (×2)
ends.svg
Ends for the crib in SVG format
selves_side.svg
Sides for the selves in SVG format
sides.svg
Sides for the crib in SVG format
get some 1/2 inch MDF
Get some 1/2 inch MDF from your local supplier. I had mine cut at the store into 32 inch length boards. When I got home I marked them and cut them into 32 by 32 boards to fit into the X-Carve 1000mm X 1000mm. Clamp the MDF board securely to the waste board and set machine to work zero. I used a touch plate to determine Z-zero.
select design files.
Select design file and prepare for cutting. you will need two of the files cut for the ends, these also have a small 10.25 inch square for the bottom self. some files I used two bits, one for rough cut to remove the bulk of material and another for detail finish cut.
Links to other Easel files for this project.
link
for the sides and bed supports.
Crib shelves side and bottom.
link
And finally the crib bed.
link
screw to gether
Use some good wood screws to secure the pieces together. I used some #6 by 1-1/4 fine thread drywall screws. I drilled pilot holes and counter sunk where the head of the screws would be.
Use a 1 inch wooden dowel rod to stabilize the bottom ends (where the round holes are).
Smaller Version for Doll
Made this file scaled down for baby doll so sister will not feel left out.
link
this is half sized and on 1/4 inch plywood have it set-up for 1/8 bit.
