The Artist Palette Cutting Board makes the perfect surface to slice and serve appetizers for a party or a small meal. The ergonomic handle allows you to carry it with ease.
No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
Choose a material and make sure to change the material and material dimensions in Easel.
Clamp Material
2 minutes
Clamp down the material. Make sure you won’t hit the clamps when you start carving!
Carve!
Once you pick your bit (1/8"is what I used), click the “carve button” and begin your carve!
Finishing
I used an 1/8 in chisel and rubber mallet, to knock the tabs off of my piece. Then I lightly sanded it with 220 sand paper.
what kind of "dremel" type of motor is used/shown for cutting?
Douglas Poston
Here are some important Crosscars taxi services you need to keep in mind.
https://crosscars.co.uk/Mitcham-Taxi
https://crosscars.co.uk/Mitcham-Minicab-booking
https://crosscars.co.uk/battersea-minicab
https://crosscars.co.uk/Gatwick-Minicab
Chelsea chauffeurs London
Douglas Poston
