Ampersand Bookend
282 opens
73 copies
4 comments
Cultivate Studios
Cultivate Studios
Chicago, Illinois
A chunky modern bookend that will brighten any room. An ampersand is always the perfect accent for your literary collection! Includes an optional instructional video for creating your own letter in Easel.
Baltic Birch Plywood
12" × 24" × 5/8" Baltic Birch Plywood
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/16 in, Material Type: Cast
$2.99
Fluorescent Pink Acrylic Sheet
$4.99
Quick Bonding Super Glue - SUPER JET
2 ounce bottle
$11.99
$19.97
Optional: Draw your own letter
Watch this video to see how I used Easel to draw the ampersand, and follow that same technique to re-create a letter of your own in Easel.
Then, follow the remaining steps using your new files.
Measure the Plywood
Measure the exact size and thickness of your material. The thickness of the material is inconsistent from piece to piece, so this is an important step.
Secure the material
4 minutes
Using double stick tape and carefully positioned clamps, secure the plywood to the wasteboard.
Carve the Plywood
35 minutes
Open this file and set the measurements to your specific piece of material, and set the cut depth to the thickness of your plywood. Use the 1/8 1FL Spiral Upcut bit (gray ring) and carve.
Carve the Acrylic
Repeat steps 2-4, set the material to acrylic and use the 1/8 1FL straight bit (black ring).
Carve the base
Open this file, set it to the measurements of your 1/16th clear acrylic and carve using the 1/8 1FL straight bit (black ring).
Assemble
Glue the acrylic ampersand to the plywood ampersand using an even coat of spray adhesive.
Glue the ampersand to the base using super strong glue, I used the Quick Bonding Super Glue – SUPER JET available on the Inventables website.
James E Martin
I like this project.
James E Martin
James E Martin
Good job my man.
James E Martin
An Tam
I am overseas, I want to buy goods, what to do ?
An Tam
Sandra Chikerotis
Hi there! I love this project so much! I was wondering if you think using MDF would work for this, or if you strongly recommend the plywood? Thanks!
Sandra Chikerotis
