Adventure Sign
1808 opens
641 copies
2 comments
Sam Alaimo
Sam Alaimo
A perfect gift for your most adventurous friend.
Carbide V-Bits
Carbide V-Bits
$15.77
MDF Wood
MDF Wood
Dimensions: 8 in × 12 in, Thickness: 3/4 in
$5.00
Add to Cart
$20.77
Engrave and Carve
I used a V-bit for this project to get all the little details of the artwork.
First, engrave the lettering, and then click over to the next workpiece and carve out the outline.
Sanding Sealer
I want to paint the words black after I carved. I found one if the easiest ways to do that is to paint the plain mdf board with a Sanding Sealer right after you carve the board.
Brush on the sealer all over the board, making sure to get in all details in the carving. Let dry for at least an hour.
Paint the letters
Once the sealer is dry, use acrylic based paint and fill in the letters. It is ok to be sloppy! You can get the paint on the surface because we will sand it off later, the sanding sealer will prevent the paint from seeping into the material.
Sand
Use a palm sander to sand the surface of the sign. This will both remove any paint that is on the surface of the sign and give the MDF a smooth finish.
ethan schweizer
What is that font you use?
ethan schweizer
Sam Alaimo
Hi Ethan, I actually purchased the artwork from this "website":https://creativemarket.com/Moloko88/352030-Adventure.-Hand-Lettering.
Sam Alaimo
