Acrylic and Wood Plant Pot
74 opens
28 copies
2 comments
Antonio Hernandez Menchaca
Mexico City, Mexico
In this project I’ll show you how to make this simple plant pot, with 2 see through acrylic sides.
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Material Type: Cast
$5.99
Walnut (×2)
6" × 12" × 3/4" Walnut
$22.86
$28.85
Materials
The materials needed for this project are the following:
- 8 × 12 inch piece of walnut, 20 mm thick
- 8 × 12 inch piece of transparent acrylic, 1/8 inch thick
- 150 grit Sandpaper
- Glue
Carving
Fasten your pieces to your X-Carve and start the carving process.
Sanding
Once all 5 pieces are done carving, find any immperfections and sand them down with your 150 grit sand paper.
Glue-up
Make sure the long wooden piece is on the bottom and glue both short pieces to the sides. Make sure the 1/8 grooves are on the inside of the piece.
Place a litte bit of glue on the grooves, not too much because we don’t want squeeze out and insert the acrylic cut outs into the grooves.
Finish
Make sure to waterproof the wood so humidity doesn’t damage it. In this case I’d go for tung oil.
Garrett
Having the grooves run the entire length of the bottom piece will result in holes on each side when assembled. This would cause a leak if it isn't sealed. I would recommend shortening the groves by 10 mm on either end of the bottom piece. That would eliminate the holes.
Garrett
Oh, that's true. Didn't even think of that, thank you very much Garrett, already fixed the design. :)
