611 dust collecting system
218 opens
83 copies
3 comments
D Burger
D Burger
A dust-collecting system for the X-Carve fitted with a Dewalt 611 spindle. It’s cut from 1/4" MDF. The ring can be cut from 1/2" MDF if desired. It is then glued onto the main platform.
Steven Williams
Is your mount attached to the system a piece of metal screwed into it? Is that also a magnet that holds the system?
Steven Williams
D Burger
There are 2 magnets glued (epoxy) to the X-Carriage. The yellow circle shows the magnet on the left side. Metal angle brackets are fixed to the vacuum assembly with screws (see them below yellow circle). The whole assembly slides up and down on the magnets for height adjustment.
D Burger
Bob Dick
Is this project not available any longer ... it does not come through to easel ? thank you
Bob Dick
