14x19 frame for a Jimmy Diresta signed print
23 opens
6 copies
233 downloads 0 comments
David Burrell - Neo7CNC
Greenwood, USA
I’ve had this signed Jimmy Diresta print for a little over 2 years. He made this on a very old printing press that he restored. I was long overdue in making a frame so I came up with this design.
Diresta.zip
The "Diresta" carving for the front of the frame
Frame instructions
You’ll need to secure a piece of Burch plywood to the X-Carve. The frame will hold a 12×17 picture or print. The total frame size is 14×19. You’ll need a 1/8 and 1/16 endmill. This frame portion of this project uses the center and top of the material as the home position. The stock material will need to be at least 15×20 inches in size. Place the clamps as close to the edge as possible to avoid interference with the cut. Tabs are used to prevent the interior and exterior material from moving during the cut. Once the initial frame is cut out you’ll need to flip it to the front and re-secure it. For the “Diresta” cut, mark out a 1×5 inch location. The home position for this cut will be the top surface and the lower left corner. I secured the lens, print and backer with some small stainless nails installed into holes I drilled into the rabbit of the frame. I finished the wood with a clear spray lacquer which I use often because I can get several coats done in a short amount of time. The spray liqueur dries very quickly. It also helps if it’s a warn, sunny day. For an extra nice finish, do a very light sanding between coats, remove the sanding residue and give the coats extra time to cure.
Made one? Log in to add yours
