12" x 12" spoil board mounting holes
65 opens
26 copies
537 downloads 0 comments
WorkinWoods
WorkinWoods
Hello everyone this is a easel file that with help you cut holes for through bolting material flat to your Inventables waste board this is the 12" version
12x12 template holes.nc
gcode for 12" mounting holes easel created
Setup and carve
alright so this template will allow you to make perfect holes in your material so you can through bolt it flat to the inventables waste board
just delete holes and place your projects where they need to go with no worries that your machine will crash into the bolt heads
just make sure under the machine tab in easel you set your saftey height to clear the bolt heads by a couple millimeters
enjoy and let me know how it works for you
