10 inch cherry clock
James Wegner
James Wegner
Duvall, WA
I designed this clock to be cut with a 1/16th inch endmill. Could be personalized with a name or logo.
PS – Bill of Materials does not have wood as a selection.
Cherry Wood
Cherry Wood
1. Mount maple
Be sure to obey whether you use the clock middle, or the lower left corner for your X Y position.
I used the center.
Mark the exact corners because you will be turning the piece over to carve the back. Must be repositioned correctly.
2. Install a 1/16th endmill
Tighten correctly.
3. Follow the Easel instructions and carve.
53 minutes
Install your dust shoe if you have one
4. Turn the piece over
Make sure the piece is as close to the previous position as possible. I designed in 1/8 inch wiggle room.
5. Change to a .25 endmill
Tighten correctly
6. Follow the Easel instructions and carve.
3 minutes
Then just sand and finish.
Roger
can you add the download files, this is a nice clock
Roger
James Nelson
File?
James Nelson
John Bjelko
can you add the file please
John Bjelko
Torben Rene Kristensen
nice job, but where do i find til file?
Eric ILETT
Yet another, where is the file?
Eric ILETT
Todd Eaton
Can you publish the file?
Todd Eaton
Bob Anderson
is the file available to buy?
Bob Anderson
gail
please send file. it is a nice clock and easy put what u like on face clock
gail
Antoinette
nice
Antoinette
Antoinette
Is the file available?
Antoinette
